ddan67
    ddan67
    What model would you recommend for a living room havin a surface about 35-40 square meters? 611 coax or 711 coax? Regards, Dan!
    Welcome to the PIEGA-fans.
    That's not an easy answer. The 711 has larger reserves at the maximum level. The 611 is more precise and detailed in sound. If your distance to the speaker is not too great (<~ 3.5 m), my recommendation is 611​.
    It's best if you can test both speakers in your room​.
      Thank you, Norbert, for your prompt reply. There will be a new house that I will move on next spring so I cannot estimate for the moment the room response and acoustic character. My first option was indeed 611. My usual listening mode is low and medium levels, mostly jazz, folk, classical music. Setup based on Weiss 501 4ch DAC, Innuos streamer, YBA Passion pre and power amp, full Siltech cables. I am just a little bit concern about low and upper bass 611 response.... will it be enough presence on it from the 2 + 3 160mm drivers?
        Yes, I personally think the 611 is absolutely great for 35 - 40 m². I have the 611 myself in a 37 m² room. The listening zone is approximately 20 m², the listening distance is ~3 meters.
        For me this is absolutely perfect.​
          Having more discussions and impressions, my conclusion is that it is somehow 50 - 50 comparison between 611 and 711. And I am talking about experienced people (dealers, resellers, audiophiles)
Ansichten: 57
Größe: 416 Bytes
            I believe you. But it is also extremely difficult to give an absolutely valid recommendation. So my advice once again: if possible, listen both speakers in your room.
              Norbert, ce premii recente a obtinut Piega pentru 611?
                ....from the translation program.
                2022&#24180;&#12434;&#32224;&#12417;&#12367;&#12367;&#12427;&#12409;&#12367;&#20170;&#24180;&#12434;&#20195;&#34920;&#12377;&#12427;&#35069;&#21697;&#12398;Stereo Sound GRAND PRIX 2022&#21463;&#36062;&#35069;&#21697;&#8230;
                More Informations in english
                Best floor-standing loudspeaker Coax 611 with high end sound.
                Zuletzt geändert von nk; 04.11.2024, 18:47.
