Hi, first I woul like to mention that I am very very new to the hifi world and I am sorry for posting in English.
I recently bought an Piega PS1 subwoofer and two Piega S3 sat speakers. From what I could find here http://www.piega.ch/download/Piega_History.pdf, the specifications for the S3 sat speakers are:
Construction time: 1997 - 2005
Model: 2-way satellite loudspeaker
Recommended
Amplifier output: 20-150 Watt
Sensitivity: 88 db/W/m
Impedance: 4 Ohm
Frequency range: 100 Hz-22 kHz +/-3 dB
Crossover frequencies: 2.5 kHz
Equipment: 1 x 8 cm LDS bass woofer, 1 x 26 mm LDS dome
Dimensions (HxWxD): 20 x 10 x 12 cm
Weight: 2 kg
And, as you probably know, the Piega PS1 subwoofer has the following: http://www.piega.ch/e/produkte/ps1.htm
From the research I done, I would need a receiver or a preamp. What I am not sure about is what specifications of power, sensitivity and impedance the unit should have.
Like I said I am very new to the game and for the moment, due to budget limitations, I will only use the two S3 sat speakers. I am not looking for high volume but more for a good sound. Also, should I connect the two speakers to the PS1 subwoofer or directly to the receiver or preamp.
Any help will be much appreciated and some drinks if you'll find yourself through Copenhagen at some point.
Recommended
Impedance: 4 Ohm
Weight: 2 kg
